Old 09-26-2012, 05:47 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
They may not even make this now but I used Thermotech on my Cobra. Easy to cut, bends as easily as a blanket and it will withstand up to 1500 degrees. I even had my transmission tunnel lined with it and worked great. It came in a roll and you just unroll it and either glue it in or use screws. I think it was about 1/4 inch thick with the shinny side out. I even replaced some of my aluminum heat reflectors with it as it lowered the temperature behind the shield more than the aluminum did.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
