Old 09-26-2012, 04:18 PM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Default More info with pics!
I have been able to get the Cobra on jackstands and take photos. It appears the front and rear calipers are identical, with one exception. The front calipers have 4 pistons (2 inner/2 outer) and have this number on the inside half of the caliper: 120-1051. The rear calipers have 4 pistons, also (2 inner/2 outer) and have an ALMOST identical number on the inside half of the caliper: CA 120-1051. Both the front and rear seem to have similar construction and appear to bleed similarly, also. Here are some photos:
Here's a photo of the front caliper:
A shot of the rotor (looks OK, no scoring):
A closer shot of the caliper:
A photo taken from underneath, showing the crossover tube:
A photo from behind, showing the flex-line...looks like quality stuff:
A shot from the top, showing the bleed valves:
Here's a shot of the pads, they look good:
Blurry, I know, but the only numbers I can find on the front calipers (120-1051):
Here is the rear setup:
A closeup of the caliper (other than the "CA", it seems identical in every respect to the front calipers):
And, finally, a shot of the pads...again, not much wear evident:
I will post this, then get a shot of the master cylinder, if that will help.
Cheers!
Dugly
YD,E./PNB
No names were changed to protect the innocent!
