Old 09-28-2012, 07:34 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
you could weld multiple bungs into wherever and when not in use plug them. use one as primary efi mang. and move the sensor to other positions to check readings, or whatever your imagination comes up with. i used one sensor in a primary pipe and asked a fairly knowledgeable tuner if i need to make any compensation to the efi programming to acct. for the pulses, etc. in reading only a primary pipe and he said no (not definitive by any means), but still take into consideration other cylinders may vary.
