Old 09-29-2012, 09:52 AM
ACBill's Avatar
ACBill ACBill is offline
I expect there is always some airflow within the air space, when using a foot box deflector plate, (regardless of material used), via convection, caused by the heat itself..Hot air rises, drawing in the cooler air from the bottom. This takes place regardless if your moving, or if your cooling fan is running. Granted, it might not be as rapid an air movement, but the hot air is not trapped.
Cobra-fast at any speed!
