Old 10-01-2012, 04:16 PM
bulletbrown bulletbrown is offline
Cobra Make, Engine: Shell Valley Cobra Kit -428 Fe Built by Clayton Racing Engines
Take a look at the early Viper fans , they have small rubber flaps on all four corners that allow air to flow threw at road speeds and close at low speeds to force more air threw the fan . It is a two speed unit . I believe it is 2600 at low speed and 3400 CFM on high.I trimmed the factory mount and it slip right in . I have use it for five years and works great . You need two relays and an over ride switch and run it direct from the Alt.
