Old 10-03-2012, 05:01 PM
saltshaker saltshaker is offline
Cobra Make, Engine: Contemporary Cobra
Default Electrical Problems
Having issues with turn signals after reinstalling the dash. Wiring harness is from EZ2Wire and switched by a VW turn signal...they worked fine before. When I turn them on either right or left all four are flashing and when I disconnect the right rear the left side works and if I switch to the right side then the left front works. The emergency flashers aren't connected....have to connect the ground. Any thoughts?????
Jon
