Old 10-04-2012, 03:52 AM
Default Sound like a ground problem
Saltshaker Jon sound like a ground problem or a broken turn signal switch. What did you change in the car?? Depending on steering columns, it's possible you lost the ground clip inside the steering column and that this is a back feed. Check repair, possible pinched wire. Rick L.
