Old 10-06-2012, 01:20 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
The 120 holder is giving you lean progression.
Start small on both, get it to idle at 3/4 turn out on the screws, then open the throttle with the speed screw to check progression.
If the 100 holder can't richen progression, even with a 65 or 70 idle jet, you'll need the third progression hole drilled.
This is more common with 48 IDAs on a little engine. Makes driveability a concern for a street car.
Gary
