Old 10-07-2012, 07:53 AM
Luce Luce is offline
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
Lopey cams misfire all the time at idle. With megasquirt, you can dictate how much authority it has to adjust the fuel based on O2 readings and how quickly it can make adjustments. I'm not even allowing it to run closed loop, but rather just using the O2 for tuning so I can make sure the data is valid by hand.
