Originally Posted by Sandwich
I must state also, that it was my brother Chris who is cleaning carbon off his pistons, designing that engine, and I will be programing it and machining it. Chris is a very good designer/ engineer, and with the help of David and Tom Kirkham we will make an exceptional engine block.
Then we want to make some billet heads! Anybody got any good ideas how to machine a good water jacket around the combustion chamber?
As others have said (and is obvious), you'll need to make a two piece head design, IMHO. I would think maching the bottom half just below the spring seat shelf and leaving bosses around the perimeter of the bottom half for small cap screws to connect the two halves and seal the head along with O-rings if necessary. With your machining skills, I would think the two halves would fit together so seamlessly, that there would be an almost invisible line at the junction.
It's all just aluminum, programming, and time. So, what else have you got to do? It isn't like you're busy is it?
Looking forward to some more innovative work from the KMS shop....
Bob
