Old 10-09-2012, 10:15 AM
carmine carmine is offline
Cobra Make, Engine: spf 2112 *427 stroker windsor
OK good pictures
As i can see in pictures there is rust present around the NIKE shaped weights.
1) Remove the silver springs. (They snap on to protruding posts).
2) lift out nike shaped weights.
3) clean rust off weights using very fine sand paper (Aprox 600 grit) or steel wool. Also use steel wool to clean rust off posts.
4) Wipe all parts clean of any grit.
5) lube post and nike weights with litheum grease.
6) re-insall.
Hope this helps.
