Old 10-09-2012, 02:53 PM
cobrafx cobrafx is offline
Cobra Make, Engine: Aussie 351C, TKO, UNK maker
How did you measure? Can you show us your "map"?
The mounting holes won't have to move, there's generally enough slop in them for offset dowels.
Mmmm....... 0 dial at 3:00 oclock and .025 at 9 oclock. AND 0 at 6 oclock and almost 025 at 12. I did it twice and came up the same. I dont have the flywheel on but will put it on this weekend and run the numbers again but i imagine they will be the same.
Jaime
edit: The right side mounting holes are VERY close to the radius of the bellhousing that the bolt heads interfere before bottoming.
