Old 10-09-2012, 04:39 PM
redmt redmt is offline
Originally Posted by cobrafx View Post
I am finding out that scattershields as a whole are definately NOT created equal. I did a search and actually found a Mcleod video that ironically used .025 as an example of an offset. Mcleod has adjustable dowels that I will have to get. Found instances of 'welding a washer after aligning'. This is my first "build" an the learning curve is VERY steep! Thanks yall for the replies. I think I will start a 'build' thread....hahahaha. Thanks yall
Jaime
If you use the adjustable dowels and it happens to move without you knowing when you take it all apart again after aligning it to put the clutch in , you'll never know it. Weld the dowels. JMHO
