Old 10-10-2012, 03:17 AM
mickmate's Avatar
mickmate mickmate is offline
Check the vertical spacing on your mounts. It should be 2.25" and is an easy swap. Even if it's not you have some options on either different spacing or blank QJ's. I make them OE style or custom and there are other suppliers out there. As Terry suggests you could use a piece of old plumbing or conduit, with washers if need be. That will set up correct spacer lengths before you cut any nice ones.
mickmate
http://www.actoncustom.com/
