Old 10-11-2012, 09:48 AM
patrickt patrickt is offline
Patrick - how did ERA run the tubes on your motor for the oil temp sensor and the oil pressure line? Over the top of the engine and down to the oil filter housing and pan - or down at the firewall and along the lower side of the block?
The oil temperature sender is located on the driver side rear of the Canton pan. The sending tube goes straight up and through a grommet located below the fuse boxes, There are two grommets there, actually, and the passenger side grommet is for the speedo cable and the driver side grommet is for the oil temperature sender. You can't see it in the second pic, but the arrow is pointing to it. The oil pressure tube runs from the filter housing directly over to the fender and up and under the fender to a hidden grommet along the firewall. You can see it in the pic and the other red arrow is pointing to it.
