Old 10-12-2012, 09:17 AM
tirod tirod is offline
That's an awful big tap. NPT isn't exactly the same as OD thread or root diameter, it's the nominal dimension for the inside of the pipe itself. 5/8" NPT is big - bigger than half inch water pipe. Which would mean adding the wall thickness and threads, too. That makes 3/4 pipe over 1" hole size.
Plus, I'm not sure how available 5/8" NPT is. NPT- National Pipe Thread Taper- ANSI B1.20.1
FWIW.
