Old 10-13-2012, 06:36 PM
patrickt patrickt is offline
Are you vacuum bleeding or pressure bleeding from the slave bleeder? Are you leaving the pushrod to the clutch fork in?
Yes, don't touch the rod to the fork. Put the surgical tubing on the slave bleeder, put the other end in a jar, crack the bleeder a bit, pump the pedal from inside the car, and the jar should fill up obviously and quickly - the tube will fill as well. If it doesn't do this, there's something wrong.
