  #24 (permalink)
Old 10-14-2012, 03:15 AM
Jethrow's Avatar
Jethrow Jethrow is offline
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
Hi sideshow.
Thx again for your past help. Another question if I may.
When providing power to the ECU, I note there is a main power feed to connect the fuse bus to the battery, and an ignition on feed to turn on the ECU when the key is set to on.
However, do you need a signal for when the key is in the start or engine cranking position? I cannot see anything for this, but I expected there would be provision for this.
Thanks again.
Tim
FFR Mk4 Roadster
HSV Clubsport R8
