Thread: Pusher Fans
  #25 (permalink)
Old 10-14-2012, 04:00 AM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
Originally Posted by A-Snake View Post
Could be left on in warm climates ;-)
The water pump fan makes a real big difference here in Alabama during hot humid weather during slow traffic or stop light to stop light crawls through congested areas. I have an aftermarket fan behind the radiator because the Ford aftermarket engine oil cooler kit I installed back when I was doing open track events and the stock fan in front of the radiator couldn't be used with the heat exchanger where I put it. (I used existing fan bracket mount holes as I didn't want to permanently modify the nacelle compartment.)
I have driven with and without the water pump mounted fan in all kinds of weather except in snow. I use to remove it during the winter because dramatically increased the time for the complete engine warm up. Now I just leave it on. (Multiple issues can lead to trouble controlling engine temperature so don't assume that management of air movement is the only thing to consider. ) In summer heat without the water pump mounted fan any situation that might lead to long or lots of closely spaced idling periods had to be avoided. The engine coolant temperature would soar fairly quickly. Mid day on a Saturday I would go around town instead of through it.
In summer with the water pump fan installed I can almost forget looking at the temperature gauge. I still look because I manually control the aftermarket fan at the radiator as needed and I still look because once a aftermarket fan motor quit in rush hour traffic in Tulsa Oklahoma on a hot day and my engine got an overhaul as a result. At the last SAAC convention at VIR we sat in line idling a long time for one of the sessions they let large numbers of attendees drive whatever they had around the track in 'touring' groups. My passenger, a long time owner of Cobras and 427 Cobras, could barely believe we sat there idling for so long and the temperatures gauges for oil and coolant didn't rise to dangerous for the engine levels. Once underway, the temperatures resettled down to normal quickly. He said he never had a Cobra or 427 Cobra he could let idle anywhere near that long.
The piece of mind a steady indicated temperature gives was just one benefit. Without the water pump mounted fan there is very little air movement on the top side of the engine. In stop and go traffic light to traffic light crawls the carburetor would get hot enough to boil the fuel inside. When the fuel starts boiling the engine runs poorly. When traffic cleared and we could go for a few miles of cruise speed the engine might leave the last traffic light running like a fugitive from a junk yard. The water pump mounted fan took care of the problem .
Dan Case
