Thread: Pusher Fans
Old 10-14-2012, 04:21 AM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
See how close that red fan and the nut holding it on the shaft are to the fragile radiator?
A not uncommon event is fatigue failure of the steel tab welded to the bird cage tube in front of the engine bay that the upper radiator bracket and gromment subassembly get attached to. The tab jiggles from road vibration, the weld cracks, and it not found and repaired the welded attachment can completely separate. Let the radiator move forward just a little and the radiator can be seriously damaged.
Dan Case
