Old 10-16-2012, 06:49 AM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
A mechanical pump is much stronger at sucking, Its pulled down by the cam, not pushed up by a spring. It'll also stop any dirt from wedging under the one way valves. Only problem, is if you have a restricted filter, on a hot day, the fuel will boil at a lower temp, causing vapor lock.
JD
