Old 10-17-2012, 01:14 AM
WardL's Avatar
WardL WardL is offline
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
I am amazed at the number of Cobras with such low miles when sold. Mine had 1,700 and I suspected a couple of speedo replacements, etc. But you can tell the difference between 1,700 miles and 5,000 miles in the wear and tear of the tires, carpet, body chips, etc. There are other places where miles show up easy. Gasoline evaporates, fill it with gas and check the other levels. I would eventually change the brake fluid and crankcase oil. It wouldn't hurt to change everything, but wheel bearing grease? You can't change rear wheel bearing grease! OK, I don't know how to change the rear wheel bearing grease. It matters more who assembled it in 2003. Are they still around?
