Old 10-21-2012, 04:03 PM
BAsque1's Avatar
BAsque1 BAsque1 is offline
Originally Posted by rpatton3 View Post
Would something as simple as an insulator gasket or spacer under your carb help?
It would be simpler than alternatives being discussed. 40 years ago, the fuel lines got wrapped with foam insulation, sometimes relocated, and an electric fuel pump and 99% of the problems were solved.
Is the ram air a filter with two hoses going under the front end of car like the 1960's Olds 442?
You have my sympathy; it is a hard problem to isolate.
Russell
Russ:
I have installed a phenolic 1" spacer already, I relocated the fule lines and are wrapped already with insulating material. The fuel pump is mechanical pumping 9 psi cold and hot so the pump seems to be working fine. I have stayed away from the electric pump thinking that I might isolate the problem other than the pump.
The ram air system has the hoses from the front grill to the carb stacked high.
tks
Lou
