Old 10-23-2012, 03:08 AM
Zedn's Avatar
Zedn Zedn is offline
Is it sitting at ride height? As it lowers the camber will change.
I have the same set up with the jag series 3. The way mine sits now, i have shims in there and the camber is still way off. I suspect i will need about the same as you so i doubt its much of an issue.
You will know if your upper arms are wrong, they dont fit right on the ball joint the other way. I know, i made that mistake in the beginning.
