Old 10-23-2012, 02:27 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
If you rev it to 3000 rpm, does it have close to the same airflow as the other cylinders?
Leakdown test by itself is a good secondary test after a compression test.
A misfiring cylinder will not alter it's own airflow reading, it will affect another cylinder in the firing order.
Example: one could have a broken inlet rocker arm, leakdown of 3%, and rough running due to no intake stroke.
Swap 2 carbs around, you may have a twisted throttle shaft.
Gary
