Old 10-23-2012, 07:26 PM
boxhead's Avatar
boxhead boxhead is offline
My opinion only.
Refer to below pic.
I think when it has been welded back together, it has not been done correct.
If the plain on lower section was not right, then this can move the upper mounts in or out (depending on way it is bowed)
When I said yesterday bowed down, I could not remember which side of mount the jag upper arm bolts too, after seeing picture I can see it is inboard.
So if centre section is too high, this in effect will move the upper mounts outward in relation to lower mounts.
Cruising in 5th
