  #21 (permalink)
Old 10-24-2012, 08:50 AM
lippy lippy is offline
Originally Posted by strictlypersonl View Post
There are outriggers from the main chassis rail with 19.25" longitudinal distance between them.
4" from the floor surface to the bottom of the chassis rail.
The box containing the brake master cylinders (in front of the muffler cavity) extends out from the main rails 5", so that the muffler "In" must be offset to the outside. The muffler "Out" must be centered or in-line with the "In" pipe. It cannot be on the opposite side.
Bob - what about the MagnaFlow 11376 (http://www.magnaflow.com/02product/s...ain&id=10390)? It is 11" long, with a 4" x 9" oval cross section and 2.5" circular inlet/outlet. This model has both inlet and outlet offset/aligned, but it can be configured several ways.
