Old 10-24-2012, 12:34 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Jon,
You stated in your previous thread that your tight valves were the cause of your low compression and high leakdown.
On your Ford V8, cylinders 1 & 2 are side by side and fed by the same carburettor.
Did you have the throttle wide open permanently while you compression tested all 8 cylinders?
If you did, and now still have 65 in 1 & 2 and 160-180 in the rest, I'd be doing another leakdown test. BUT if the leakdown doesn't show your loss, you could have a split bore between cylinders.
If you didn't have the throttle wide open when you did the compression test, then if the affected cylinders were trying to draw through a almost closed carb, you get low numbers.
It is highly unlikely to have low even compression on adjacent cylinders due to unseated new rings.
Gary
