Old 10-28-2012, 03:56 AM
Default What bellhousing is on the car??
dcdoug Doug if you are running a Lakewood with a block protector, this is the problem with the starter and flywheel teeth being chewed up. I can't answer for the Quicktime bell setup. The only way to get complete engagement is to cutout the block saver around the start hole. The starter must be bolted FLAT to the bellhousing. I ran a Tilton for 14 years and replaced the bendix drive 1 time. The engagement will increase 3/16" of an inch and give you better engagement. I tryed running an OEM starter and had the problem of when hot the motor didn't want to crank. Mini starter is the better way to go IMO. You also want a .35"-.55" clearence between the teeth of flywheel and teeth on starter drive. Rick L.
