Old 10-28-2012, 07:00 PM
jonalley jonalley is offline
Cobra Make, Engine: FF 302 cam,balanced,48 IDA Webers
Eljaro, That's a serious amount of dismantling. Is there any way I can test for such leaks-e.g. the way you use soap suds on a gas pipe assembly. I know it's suction not pressure but ???
I've gone over all the carb and maniflod bolts to test if any were loose. All seemed fairly tight. If I can I will start the car tomorrow( Monday here) and see if it runs the same. Then I suppose I have no other recourse but to start taking things apart. Thanks all. Jon
