Old 10-29-2012, 08:32 PM
Cobra #3170 Cobra #3170 is offline
Default Throttle linkage
Cable will allow you to design an opening cam that will make the car far more drivable because you can make the first two inches of travel only open the throttle 25%. The OEM's went away from linkage for a reason, broken engine mount = full throttle whether you want it or not. It doesn't look original but is a lot better from a drivability standpoint. I have a 1650 cfm throttle body that was absolutely undrivable until I changed to cable with a slow take up cam.
