Old 10-31-2012, 12:56 AM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by razerwire View Post
With the engine running you can use carb cleaner to find air leaks............."
you can also use plain water in a spray bottle. The rpm will change if you spray it towards a leak, just the same as carb cleaner does, only WITHOUT the fire possibility,
Z.
'65 K code Mustang
'66 Galaxie 500
