Actually I believe #9 is correct. Under #6 it says: " Mark the center height on the wall horizontally from the ground of each headlight "minus two inches", again using masking tape." So that allows for the high beam issue.
I don't remember where I got this but I have used it for years and never had a problem. Yes you do need to do this on a level surface. At 25' back I knew exactly what size blocks to put under which tires.
Wayne
Added: I guess if you didn't drop the tape down 2" under #6 and you used the high beams under #9 that would work. Never tried it that way.
Reason: Last added.
