Quite keen on the hood scoop....mine is "short" and I cannot run a decent air cleaner.
Do you have any dyno numbers on the 331???
How do you like the 165's? I would like to rebuild my box stock 5.0 with a set of AFR165C's, the factory "competition" model. Might put a stroker in it, if the block will stand it I would go with a 347 stroker, though...might use that longer rod/piston combo recommended by someone a page ago...at any rate, your ride is one primo A/C and you should be incredibly proud!
Cheers from the U.S.!
Dugly
