Old 11-01-2012, 07:01 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Since Mando Asked for an update... Plus we need more build threads, shed threads and pics on this forum to keep it interesting.
I've been doing work around the house and shed lately and not much on the Cobra. I'm finally starting to get the inside of the shed looking how I want it. I've put up some internal walls and lined out the machine shop area and set it up a bit better.
I wanted a bit of a rustic look for the inside so lined the bottom with pine lining boards and stained them merbu and lined the top with zincalume. I also fitted a couple of skylight sheets over the area as it got quite dark once the walls went up. The silver corrugated tin reflects a lot of difused light so has really brightened up the area in both the day time and night under fluros.
I'm working on an office area with a dunny and a shower next. over the winter I got the sewer line run in and connected up. Mud everywhere.
Water tanks are all done and hooked up. Full now too! trenches are all filled in but I'm thinking I'll redo the overflow down pipes and drill through the slab. I'm already tired of having to mow around where they drop over the edge of the slab. I've just finished moving the overflow on the house tank to put it through the slab for the same reason.
Mike Murphy
Melbourne Australia
