Old 11-02-2012, 04:48 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
I found this if it helps:
"...the TFI module is called a Thick Film Ignition module, what this does is control the spark output to your distributor. It was a huge recall on alot of ford vehicles because they used to be located directly on the distributor where most of the engine heat is, hence why it is now near your air filter. What would happen to these modules is the film inside would dry out causing condensation to get on the controls and short the module out causing complete power loss of power breaks, power steering and the like..."
SPFWiringDiagrams@Comcast.net
