Old 11-06-2012, 06:02 AM
DAVID GAGNARD's Avatar
Originally Posted by jhv48 View Post
I wish I knew. When the heads were removed, there was no cross hatch visible in any of the cylinders. Should have been visible with 13,000 miles. There were even a couple of tiny gouges in two of the cylinder walls. A couple of lifters were showing abnormal wear. The heads are being rebuilt due to wear. Either this engine was just a POS from the get go or maybe it was accidentally run without oil before I received the car. Who knows?
Last year I bought a car in a junk yard that had a 1994 Mustang GT 302 engine transplanted in it, it was in fairly good running condition, I mainly needed the block and a few other parts off the engine...Best we could tell, that engine had over 75,000 miles on it and when I tore it down,you could still see the cross hatch in all the cylinders and this engine did have a rough life up to that point.....
I don't have any idea what happened to your engine, but what you describe should not have happened in 13,000 miles and what other have been describing with their Roush engines with that or less mileage is not good...
David
DAVID GAGNARD
