Old 11-09-2012, 02:59 PM
BMK's Avatar
BMK BMK is offline
Talking Fun in the Kirkham
I am having trouble getting the smile off my face...
Had my Kirkham now for just on 5 weeks and travelled 5000 kilometers so far - 3000 miles in US talk..
I am enjoying the Cobra, it's handling, braking and general comfort is fantastic.
I made a few changes to give me more room - pressed the floor down under the seat to give the seat base more down direction. This "Bernie bubble" as it has been called allows my 90kg - 200lb - to drop down about 20mm - 1 inche. I also pressed the inner guard to allow the seat to go back 30mm.
As the weather can get quite cold I have fitted a roof.
I have had an opportunity to give the Cobra some spirited driving around the Great Ocean Road and through the winding coastal hills.
The only small problems I have found are -
The ignition key hits my left knee when I get really moving in corners changing gears and I turn the ignition off. I rectified this by taking spare keys off the ignition key. May move the ignition to the centre of the dash..
I have found the fuel/gas tank gets pressured up and bangs and complains
loudly when I open the gas cap. The valve on the fuel/gas cap is working. the tank bangs whilst filling it with fuel. I will check this as I don't want to break welds.
I have a few oil leaks, but that is to be expected. Once I run it a little more and re change oils etc. out I will re tension everything.
The 468 aluminum Shelby has lived up to my expectations. It is a real hang on experience.
I promise I will not wear it out to quickly..
Cheers.....
Bernie Knight
