Old 11-10-2012, 05:30 PM
r67cat r67cat is offline
Cobra Make, Engine: Superformance 428 FE
Adding additional torque to the center nut will not reduce the play. The hub assembly has shims that control the preload (really end play)on the bearings. You might check out this thread that describes how to set up the bearing correctly. Rick
JagFORUM Logon
