Old 11-12-2012, 01:42 PM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Lou, so it looks like your shock is running about 14 1/4" or so at ride height compared to my 12 3/4" with a 1 1/2" difference. Yours would be close to center for that 7563/7564 shocks. Even if I cut off the upper tabs and reweld some higher it's still not going to be enough.
You know I called B&B and told them this just didn't look right with the shock in the higher clip notch. They said it would settle down when the weight gets on it. I guess I will see what they have to say tomorrow.
Thanks a lot Lou.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
