Old 11-13-2012, 08:45 AM
lnfletcher's Avatar
lnfletcher lnfletcher is offline
Cobra Make, Engine: B&B 427 Stroked Windsor TKO 600 w/3.50 posi 9"
Originally Posted by Wbulk View Post
Thanks for the information Larry. I just have to determine what shock I have. If this 806990023711 crosses over to 7563 or 7564 shocks. It looks like the one I have may be to long.
Larry what is your fender lip to ground height and what do you think about the 185 lb. springs.
Added:
One other thing. Does your upper mounts hang down as far as mine?
My fender lip to ground is 27.5" an as far as the 185 lbs springs, I'm not sure my wife would rided with me if they were any stiffer! I have bottomed out on sevier bumps but very very rarely. I am 6,2 240 so I do put some weight into it!
My mounts were bolt on the top, not welded so they are a little different. Mine had a U shaped piece that had a bolt the went through the upper frame with a nut on the other end. But it looks very similar.
