Old 11-14-2012, 07:29 AM
Cobra #3170 Cobra #3170 is offline
Default Original Slave Cylibde
I don't think the poriginal type slave will work with the Lakewood. The cars used the Ford bellhousing and the slave is mounted differently than a Lakewood does.
I had a Lakewood bell housing at one time on CSX3170 and I used the stock slave cylinder and bracket. As I recall it used a tapped hole in the block and then a bolt that retained the bell housing to the block. I now have the stock bell housing back on and that same slave cylinder and mounting bracket so I did not modify it. I can't recall if there were any adapter parts fabricated for mounting to the Lakewood but don't think there were.
