Old 11-17-2012, 09:55 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Try, borrow or get somehow a normal ignition ....ie coil and distributer....in other words bypass the MSD, and see if you have any luck...also make sure that your ignition switch is allowing current to pass to the ignition when you are cranking.......it could be the ignition switch...
