Old 11-18-2012, 08:01 AM
Dwight's Avatar
Dwight Dwight is offline
Smile Jag rear end, shocks
I have a lot of pictures that I took when we replaced Jeff's shocks.
I did not see any way to raise or lower without major rework. I had to make a "tool" to install the springs onto the shocks with my 30 ton press. That's the hard part of the whole job. We had replace Ron's Jag front shocks on his Shamrock a few years ago and had worked out a system then.
I don't think you can install a spacer under the spring but if you did I don't think it will change the length of the shock.
Jeff's springs looked used, more rust pits than the years and mileage of his Cobra would have caused.
Dwight
If you need more pictures of the rear end email me at algunruner@aol.com
