Old 11-18-2012, 10:08 PM
Mando's Avatar
Mando Mando is offline
DaveW, I had the same problem with my drivers door which sat about 40mm higher than the body. To fix it my fiberglass guy had to remove the glass encasing the square tube the door striker is bolted to, cut it of, reposition and then re-weld it.
The curved section behind the square tube came nearly flush with the rolled edge of the body. To get the glass to sit back so the carpet wouldn't protrude from the body lip above, my guy cut the glass into 10-15mm vertical strips, pushed the wall into the new position then re-glassed everything up again. He did a brilliant job!
Regards.
Mando
