Old 11-19-2012, 01:24 PM
Mtbnutty Mtbnutty is offline
Default Need help identifying lockheed master cylinder
Hi All,
After a couple of decades, it's time take my cobra out of mothballs. It was a kit purchased at a place called G & R Engineering in Sacramento. It was similar to the Arntz but without the bulges and additional length, I think. From what I remember the kit was also close to the Butler, and for a short time my cobra worked on by Bennett Cobra in Hayward.
Anyhoo, I got the thing running again and worked out a few kinks but found the brake master cylinders and clutch master cylinder leaking. So, either replace the master cylinders or rebuild them. Only trouble is that I don't have any part numbers. The pedal assembly was purchased from Bennett and the old receipts show no details other than "pedal assembly".
Let me describe the pedal assembly and I'm hoping someone here knows what I have:
Underfloor pedal assembly with (2) master cylinders and (1) clutch master cylinder. Front and rear brake m/c's activated through a balance bar. All m/c's have what appear to be older (english) Lockheed (tin can) reservoirs. The attached pic is not from my car but looks identical to the brake master cylinders. The clutch m/c also looks very similar to the pic with a few minor differences.
I have not taken out the m/c's yet and really don't want to do so until I get this sorted out. Or, maybe I need to remove them to see if they're stamped with part numbers?
Any help here will be greatly appreciated.
