Old 11-21-2012, 08:47 PM
Tom Howland Tom Howland is offline
Junior Member
Cobra Make, Engine: 1980 Arntz 427W, Webers, TKO600, Jag IRS
Originally Posted by jhv48 View Post
As long as BOTH your pcv valve AND the opposite valve cover breather dump into an air cleaner, you will pass inspection for your sb100 exemption. All else being equal.
I tried that in 1/11 SB100 inspection and did not pass. Had to drill and tap the intake manifold and run the PCV valve to that point. Bar would not allow anything run to the air filter.
Tom
