Old 11-26-2012, 01:59 PM
cobra 53's Avatar
cobra 53 cobra 53 is offline
Cobra Make, Engine: NAF 289 Blue/White strips
Thanks for your advice!
Today I took the time to make the pad bedding ref. to Zeckhausen Racing .
After the bedding I realized that the alignment between rotor and caliper has not been 100%.
I adjusted the left and right caliper approx. 0.3mm or 0,011".
I repeated the bedding procedure and the rotors showed an equal contact/ square.
I also changed the balance between front and rear brake. Too much front brake pressure.
More I will let you know after the next test.
Rico
Rico, NAF 289
