Old 11-27-2012, 04:19 AM
dc7531 dc7531 is offline
Cobra Make, Engine: Harrison no. 9, Pace GT40 no. 14 build
Originally Posted by Modena View Post
The sender I am using (VDO) came with fiber washers for the bolts, cork gasket for the top of the flange and some sort of rubber-type gasket for the inside-tank-side of the flange.
Modena, my sender is also VDO, I remember the fibre washers and cork gasket but can't recall seeing that rubber gasket you mentioned (it has been several months since I last took the sender out though and my memory is not the best) I wont be home until the weekend but will clean up and check that all the bits are there asap.
Derek
