  #21 (permalink)
Old 11-27-2012, 12:04 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by qsl View Post
anyone find a solution for this? I have a ported intake for the pcv valve to hook up, but I still failed. They said it needs to be closed. So i need to remove the vent on the other valve cover and run a hose somewhere to the carbs? Can you just plug off that vent?
You cannot plug off the vent.
Crankcase pressure will skyrocket positive or negative on acceleration or deceleration respectively.
Run the largest i/d hose you can fit to the closest carb aircleaner base.
Ideally, one hose per aircleaner:
-10 to junction block to 4 x -6 to carb air cleaner bases.
Gary
